High Resolution Camera
A camera with a static resolution higher than 8MP is called a High Resolution Camera.
High-resolution cameras output denser image quality with more pixels per inch (PPI), so as to create high-quality crisp images. In practice, the resolution of images produced by high-resolution cameras should be above 8 megapixels.
It is not news to see high-resolution images on your smartphone or from DSLR photos. But when it comes to the Nvidia Jetson camera, the story is more impressive. Especially when Arducam sped up on its way of breaking the resolution limits, bringing higher and higher resolution items.
Product
Product Image | SKU | Sensor | Resolution | Pin/Connect Type | Features | Lens Type | Field of View(H x V) | Focus Type | IR Sensitivity |
B0251 | IMX477 | 12MP | 22/Top | Mini Size | M12 Lens | 75° (H) x 56° (V) | Manual Focus | 650nm IR-cut filter |
B0279 | High Resolution | / | / | |||||
B0249 | CS Mount | CS Lens | 75° (H) x 56° (V) | Manual Focus | 650nm IR-cut filter | |||
B0273 | High Resolution | M12 Lens | Motorized Focus | 650nm IR-cut filter | ||||
B0274 | Day and Night Vision | CS Lens | 65° (H) x 49° (V) | Manual Focus | Motorized IR-cut filter | |||
B0250 | 15/Bottom | HDMI Extension Kit | CS Lens | 65° (H) x 48.8° (V) | Manual Focus | 650nm IR-cut filter | ||
B0167B12 | 15pin/22pin | Pan-Tilt-Zoom Kit | Zoom Lens | (96~33)°(H) x (72~24)°(V) | Motorized Focus | Motorized IR-cut filter | ||
B016712MP | |||||||||
B0303N | 22/Top | Wide Angle | Stock Lens | 95° (H) x 72° (V) | Fixed Focus | 650nm IR-cut filter | ||
B0371 | IMX519 | 16MP | 15/Bottom | MIni Size | Stock Lens | 66°(H) x 49.5°(V) | Autofocus | 650nm IR-cut filter |
B0214(Discontinued) | IMX298 | 16MP | 22/Top | High Resolution | Stock Lens | 60°(H) x 45°(V) | Motorized Focus | 650nm IR cut filter |
B0323(Discontinued) | 62°(H) x 46°(V) | |||||||
B0367 | AR1820HS | 18MP | 22/Top | High Resolution | M12 Lens | 75°(H) x 56°(V) | Manual Focus | 650nm IR-cut filter |
B0324 | IMX230 | 21MP | 22/Top | High Resolution | Stock Lens | 64°(H) x 48°(V) | Autofocus | 650nm IR-cut filter |
Hardware
Locate the camera connector (CSI). It’s on the side of the carrier board, opposite to the GPIO pins.
Pull up on the plastic edges of the camera port. Do it gently to avoid pulling it off.
- Push in the camera ribbon. Make sure the contacts are facing the heatsinks. Do not bend the flex cable, and make sure it’s firmly inserted into the bottom of the connector.
Ribbon Cable Contacts – 15pin-15pin
Silver Contacts facing inside to the heatsinks
Ribbon cable fully inserted to the bottom of the CSI connector
- Push the plastic connector down. Do it while holding the flex cable until the connector is back in place.
Software
For Native Cameras:
The following sensors are Natively Supported by Nvidia Jetson:
IMX219 | 8MP |
IMX477 | 12MP |
IMX519 | 16MP |
You can refer to the following page for the detailed information of the quick start:
Quick-Start-For-Nvidia-Jetson-Native-Camera
For Jetvariety Cameras:
The following sensors are Arducam Jetvariety Cameras:
IMX298 | 16MP |
AR1820HS | 18MP |
IMX230 | 21MP |
For Jetvariety Cameras, you can refer to the following doc:
