21MP IMX230
Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Using Arducam Pivariety camera modules, users can get better performance and a wider variety of camera, lens options. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and camera modules (V1/V2/HQ). Now Arducam made it possible to provide well-tuned ISP for Pivariety camera modules with Auto Exposure, Auto White Balance, Lens Shading Correction, etc.
Image Sensor 21MP
Max. Resolution 5344H×4016V
Pixel Size 1.12um×1.12um
Optical Format 1/2.4”
Lens Spec Focal length: 4.77mm, F.NO: 1.75±5%,
FOV: horizontal 64deg
Focus Type Motorized focus,
programmable focus control
Frame Rate 5344×4012@9fps,
3840×2160@10fps,
2592×1944@15fps,
2656×2004@30fps,
1920×1080@30fps,
1280×960@120fps,
1280×720@120fps,
640×480@120fps
Sensor Output Format RAW10
ISP Output Format The output image format of JPG, YUV420, RAW, DNG The output video format of MJPEG, H.264
Interface Type 2-Lane MIPI
Board Size 38mm×38mm
Detailed parameters
Product Image SKU Pin/Connect Type Features Lens Type Field of View(HxV) Focus Type IR Sensitivity
B0324 22/Top High Resolution Stock Lens 64°(H) x 48°(V) Autofocus 650nm IR-cut filter
Next
Quick Start
