Quick Start Guide for Arducam CamArray HAT Kit
Hardware
Dimension
Pin Definition
MIPI RX0/RX1/RX2/RX3
Connector Part Number:F32R-1A7H1-11022
FFC: Top on One Side, Bottom on Other, Backers on Both Sides(Opposite side)
Pin No. PIN NAME TYPE DESCRIPTION Level
1 DGND Ground Power ground GND
2 MDN0 Input Pixel Data Lane0 Negative 1.2V
3 MDP0 Input Pixel Data Lane0 Positive 1.2V
4 DGND Ground Power ground GND
5 MDN1 Input Pixel Data Lane1 Negative 1.2V
6 MDP1 Input Pixel Data Lane1Positive 1.2V
7 DGND Ground Power ground GND
8 MCN Input Pixel Clock Output Form Sensor Negative 1.2V
9 MCP Input Pixel Clock Output Form Sensor Positive 1.2V
10 DGND Ground Power ground GND
11 NC NC NC NC
12 NC NC NC NC
13 DGND Ground Power ground GND
14 NC NC NC NC
15 NC NC NC NC
16 DGND Ground Power ground GND
17 POWER-EN Output Camera Power Enable 3.3V
18 XCLK Output Camera XCLK 1.8V
19 DGND Ground Power ground GND
20 SCL Output SCCB serial interface clock Output 3.3V
21 SDA I/O SCCB serial interface data I/O 3.3V
22 VCC Power 3.3V Power supply POWER
MIPI TX
2 MDN0 Output Pixel Data Lane0 Negative 1.2V
3 MDP0 Output Pixel Data Lane0 Positive 1.2V
5 MDN1 Output Pixel Data Lane1 Negative 1.2V
6 MDP1 Output Pixel Data Lane1 Positive 1.2V
8 MCN Output Pixel Clock Output Form Sensor Negative 1.2V
9 MCP Output Pixel Clock Output Form Sensor Positive 1.2V
11 MDN2 Output Pixel Data Lane2 Negative 1.2V
12 MDP2 Output Pixel Data Lane2 Positive 1.2V
14 MDN3 Output Pixel Data Lane3 Negative 1.2V
15 MDP3 Output Pixel Data Lane3 Positive 1.2V
17 POWER-EN Input Camera Power Enable 3.3V
18 NC NC NC NC
20 SCL Input SCCB serial interface clock Input 3.3V
22 NC NC NC NC
Hardware Connection
Connect CamArray HAT(Variable Baseline version) to Raspberry Pi:
camarray-1
Connect four-cameras to Camarray HAT(Variable Baseline version):
camarray-2
Connect two-cameras to Camarray HAT(Variable Baseline version):
camarray-3
Connect Stereo camera kit(Fixed Baseline version) to Raspberry Pi:
Tip
Arducam has released binocular cameras with two connection methods: 15pin and 22pin connected cameras
  • This is the connection of 15pin binocular camera:
camarray-4
  • This is the connection of 22pin binocular camera:
B0263-multi
Software
Find your corresponding camera in the following two links, and then execute the following command
Native cameras
Product Image SKU Sensor Resolution Pin/Connect Type Features Lens Type Field of View(HxV) Focus Type IR Sensitivity
B0347R IMX477 12MP 15/Bottom Stereo Camera M12 75°(H) x 56°(V) Manual Focus 650nm IR-cut filter
B0396 IMX219 8MP Quad Camera Stock Lens 62.2° (H) x 48.8(V) Fixed Focus
B0397 IMX477 12MP M12 75°(H) x 56°(V) Manual Focus
B0265R IMX477 12MP 15/Bottom Stereo Camera CS 65°(H) x  48.7°(V) Manual Focus 650nm IR-cut filter
B0484 IMX708 12MP 15/Bottom Quad Camera Stock Lens 120°(D)x100°(H)x72°(V) Autofocus 650nm IR-cut filter
B0388 IMX519 16MP 15/Bottom Quad Camera Stock Lens 66°(H) x 49.5°(V) Motorized Focus 650nm IR-cut filter
B0402 64MP 64MP 15/Bottom Quad Camera Stock Lens 72°(H) x 54.6°(V) Motorized Focus 650nm IR-cut filter
Supported Platforms and OS
Note for Supported Platform and OS
Platform Bookworm(rpicam) Bullseye(libcamera/rpicam) Buster(raspistill)
Raspberry Pi 5 √
Raspberry Pi 4B / 3B+ / 3A+ / Zero / Zero 2 W √ √
Raspberry Pi CM3 / CM3+ / CM4 /CM5
IMX219 Multi-camera Kit:
Please make sure you are running the latest version of Raspberry Pi OS. (January 28th, 2022 or later releases, Debian version:11(Bullseye) and Bookworm OS). You need to update the config file and use libcamera apps.
  • For Raspberry Pi Bookworm users running on Pi 5, please do the following:
camera_auto_detect=0
dtoverlay=imx219
#Save and reboot.
If you want to enable the camera kit on the cam0 port of Pi5, please refer to the following modifications:
dtoverlay=imx219,cam0
#Save and reboot.
  • For Raspberry Pi Bookworm/Bullseye users running on Pi 4, please do the following:
Bookworm OS on Pi4
dtoverlay=imx219
#Save and reboot.
Bullseye OS on Pi4
sudo nano /boot/config.txt
dtoverlay=imx219
#Save and reboot.
  • For Bullseye users running on Pi 0 ~ 3, please also:
Open a terminal
Run sudo raspi-config
Navigate to Advanced Options
Reboot your Pi
Open a terminal
Navigate to GL Driver
Select GL (Full KMS)
Reboot your Pi
  • For Raspberry Pi Compute Module 3/4
The latest software only supports one camera at this time, CM4 uses CAM1 by default.
IMX477 Multi-Camera Kit:
dtoverlay=imx477
#Save and reboot.
dtoverlay=imx477,cam0
#Save and reboot.
Bookworm OS on Pi4
dtoverlay=imx477
#Save and reboot.
Bullseye OS on Pi4
dtoverlay=imx477
#Save and reboot.
Open a terminal
Reboot your Pi
Open a terminal
Reboot your Pi
IMX708 Multi-Camera Kit:
dtoverlay=imx708
#Save and reboot.
dtoverlay=imx708,cam0
#Save and reboot.
Bookworm OS on Pi4
dtoverlay=imx708
#Save and reboot.
Bullseye OS on Pi4
dtoverlay=imx708
#Save and reboot.
Open a terminal
Reboot your Pi
Open a terminal
Reboot your Pi
IMX519 Multi-Camera Kit:
  • Download the bash scripts
  • Install libcamera and libcamera-apps
./install_pivariety_pkgs.sh -p libcamera
dtoverlay=imx519
#Save and reboot.
dtoverlay=imx519,cam0
#Save and reboot.
Tip
If you are running this camera kit on earlier Raspberry Pi Bullseye OS versions (the versions before Bullseye 6.1.21). Please refer to the following page:
IMX519 Camera on Raspberry Pi(Before Raspberry Pi Bullseye OS 6.1.21 version)
Bookworm OS on Pi4
dtoverlay=imx519
#Save and reboot.
dtoverlay=imx519
#Save and reboot.
Open a terminal
Reboot your Pi
Open a terminal
Reboot your Pi
64MP Hawkeye Multi-Camera Kit:
  • Install Camera drivers
Tip
The Raspberry PI Bookworm OS can turn on arducam_64mp directly by configuring dtoverlay=arducam-64mp, but the driver may not be up to date and some issues have not been fixed. If you run into problems, try using the installation script below to install the latest driver.
./install_pivariety_pkgs.sh -p 64mp_pi_hawk_eye_kernel_driver
Please reboot your Pi when you finish the installation.
sudo reboot
#Save and reboot.
dtoverlay=arducam-64mp,cam0
#Save and reboot.
Tip
64MP Camera on Raspberry Pi(Before Raspberry Pi Bullseye OS 6.1.21 version)
Bookworm OS on Pi4
#Save and reboot.
#Save and reboot.
Open a terminal
Reboot your Pi
Open a terminal
Reboot your Pi
Access Raspberry Pi Native Camera
Arducam Pivariety cameras
B0263 OV9281 1MP 15/Bottom Mono Global Shutter Stereo Camera M12 70°(H) x 43.75°(V) Manual Focus without IR-cut filter
B0264 OV2311 2MP 83°(H) x 67.5°(V)
Image B0492R AR0234 2MP 22/Bottom Color Global Shutter M12 120°(D)×90°(H)×75°(V) Manual Focus Integrate IR-cut filter
B0350 IMX219 8MP 15/Bottom 360° Stereo Camera M12 220°(H) x 166°(V) Manual Focus 650nm IR-cut filter
B0331 OV9782 1MP Color Global Shutter Quad Camera 75°(H) x 46.8°(V) without IR-cut filter
Image B0266 OV9281 1MP 15/Bottom Mono Global Shutter Stereo Camera M12 70°(H) x 43.75°(V) Manual Focus without IR-cut filter
B0267 75°(H) x 46.8°(V)
Tip
If you do not find your camera please contact us.(support@arducam.com)
Raspberry Pi 5 √
Use libcamera/rpicam to access Arducam Pivariety Camera
Info
If you are using Arducam Pivariety Multi-Camera kit on Raspberry Pi 5, please connect your camera module to camera 1 port.(The camera 1 port is enabled default.)
Raspberry Pi Bullseye OS 6.1.21 and Later/Bookworm OS
Step 2. Install libcamera
Step 4. Modify .Config file
dtoverlay=arducam-pivariety
#Save and reboot.
dtoverlay=arducam-pivariety,cam0
#Save and reboot.
Bookworm OS on Pi4
#Save and reboot.
#Save and reboot.
Open a terminal
Reboot your Pi
Open a terminal
Reboot your Pi
Step5. Use libcamera/rpicam to access Arducam Pivariety Camera
Preview 5 seconds.
rpicam-still -t 5000
If you don't have a display screen, you can save an image without displaying it. And an image of test.jpg will be saved in the current directory.
Step 1. Install Bash Script
Step 4. Install Camera drivers
# PivarietyPlease se
./install_pivariety_pkgs.sh -p kernel_driver
sudo reboot
Step5. libcamera-apps
Preview 5 seconds.
If you do not have a display screen, you can save an image without displaying it. And an image of test.jpg will be saved in the current directory.
Extension Solution for Multi Camera
Extend HAT-Pi
Extend the connection between the HAT and Raspberry Pi, you can consider the following two solutions:
  • Option1:
SKU: B0091 HDMI cable
It transmits MIPI signal through HDMI cable, which can be transmitted farther than through FFC cable, about 3M.
Extension-Multi-2
  • Option2:
SKU: U6248 LAN cable
It transmits MIPI signal through LAN cable, which can be transmitted farther than through FFC cable, about 10M.
Extension-Multi-3
In this form, we have tried 3 meter of LAN cable before, and it works normally. The HDMI cable should be longer.
Switch Composition Mode
Arducam Team has achieved the channel-switch function on some Quad-Camera kits. You can refer to the following guide to switch the Composition Mode.
Check I2C node:
You can input the following command to check if your camera kit supports switching the composition mode.
pi@raspberrypi:~ $ i2cdetect -l
i2c-1   i2c         bcm2835 (i2c@7e804000)              I2C adapter
i2c-22  i2c         bcm2835 (i2c@7e205000)              I2C adapter
i2c-0   i2c         i2c-22-mux (chan_id 0)              I2C adapter
i2c-10  i2c         i2c-22-mux (chan_id 1)              I2C adapter
If you get some messages as above, then you can continue the following steps:
Detect I2C signal:
Take i2c 10 node as an example
i2c10
Select the Channel:
hat-i2c
Example:
The examples in this documentation use Raspberry Pi 4 as the reference platform, where the i2c bus number is 10. For Raspberry Pi 5 implementations:
• Camera 0 interface: i2c bus 6
• Camera 1 interface: i2c bus 4
Please adjust your i2c bus configurations accordingly when deploying on different Raspberry Pi hardware platforms.
# Set to single channel 0
i2cset -y 10 0x24 0x24 0x02
# Set to single channel 1
i2cset -y 10 0x24 0x24 0x12
# Set to single channel 2
i2cset -y 10 0x24 0x24 0x22
# Set to single channel 3
i2cset -y 10 0x24 0x24 0x32
# Set to double channel (single channel 0 and single channel 1)
i2cset -y 10 0x24 0x24 0x01
# Set to double channel (single channel 2 and single channel 3)
i2cset -y 10 0x24 0x24 0x11
# Set to four in one mode (Default)
i2cset -y 10 0x24 0x24 0x00
Test:
Single-channel test:
#Single channel test
pi@raspberrypi:~ $ i2cset -y 10 0x24 0x24 0x02
pi@raspberrypi:~ $ rpicam-still -t 0
After setting the channel, you can directly use the rpicam command to capture images.
Dual-channel test:
#Dual channels test
pi@raspberrypi:~ $ i2cset -y 10 0x24 0x24 0x01
By default, the quad-camera kit works in synchronized 4-channel mode, and Raspberry Pi recognizes the whole kit as one camera Any manual focus or camera control adjustments (exposure/gain/white balance/etc.) will also be applied to 4 cameras at the same time.
If you encounter any problems when using the camera kit, please directly contact support@arducam.com for help.
