TOF Camera
A Time of Flight camera module featuring a MIPI-CSI 2 connection and offering up to 4-meter measuring range with sub-2cm precision, designed and optimized exclusively for Raspberry Pi & Nvidia Jetson boards.
Specification Arducam ToF Camera
Price $29.99 – Kickstarter $50 – MSRP
Number of Effective Pixels 240×180
Image Size 1/6″
Max. Frame Rate (Sensor) 120fps
Max. Depth Frame Rate (Raspberry Pi) 30fps, 4-phase
Raspberry Pi OS Bullseye (32-bit/64-bit) / Bookworm (32-bit/64-bit)
TDP 3.5W Power supply for Pi should be at least 5V/4A
Supported Platforms Pi 2/3/CM3/4B/5 Zero W/Zero 2 W/CM4
Modulation Frequency 75MHz/37.5MHz
Viewing Angle 70° Diagonal
Measurement Distance Far Mode: 4m Near Mode: 2m
Light Source 940nm VCSEL illuminator
Board Size 38mm x 38mm
Interface MIPI (2-Lane)
Output Formats 4-phases RAW Frame,
Depth Frame,
Grayscale Amplitude Frame
Product
Product Image SKU Pin/Connect Type Color Type Features Light Source Field of View(HxV) Focus Type IR Sensitivity
B0410 15/Top Color Real-time point cloud and depth map 940nm VCSEL illuminator 62.8°(H) x 37.9°(V) Fixed Focus without IR-cut filter
Supported Platforms and OS
Note for Supported Platform and OS
Platform Bookworm(rpicam) Bullseye(libcamera/rpicam) Buster(raspistill)
Raspberry Pi 5 √
Raspberry Pi 4B / 3B+ / 3A+ / Zero / Zero 2 W √ √
