Camarray Firmware Information
This page is mainly designed to help users identify the firmware information of different multi-camera kits to solve the problem of using them on some specific JetPack versions/development boards.
About the Firmware of Arducam Multi-Camera Kit
About Arducam Jetvariety Multi-Camera Kit
The Arducam Jetvariety multi-camera series is not limited by the JetPack system version, and all versions can be used normally.(On the version driven by Arducam).
SKU Sensor
B0266 OV9281
B0267 OV9281
B0263 OV9281
B0264 OV2311
B0331 OV9782
Latest Firmware Date
Tip
The products (with SKU) listed in the following list have compatibility issues in L4t 35.x Jetpack5.x and above versions, you need to meet the firmware version date requirements(no early than the date below) in the table to work normally in L4t 35.x Jetpack5.x and above versions (otherwise you can only use them on previous versions):
SKU Sensor Latest Firmware Date
1x2 Dual Camera Kit
B0265N IMX477 2023.03.07
2x2 Quad-Camera Kit
B0388 IMX519 2023.02.03
B0396 IMX219
B0397 IMX477
How to Check the Firmware Information
  • Currently Supported Hardware Platforms: NVIDIA Jetson Nano, NVIDIA Jetson Xavier NX, NVIDIA Jetson Orin Nano, NVIDIA Jetson Orin NX. (The system versions supported by different hardware platforms is different. For details, please check: Arducam Cameras for NVIDIA Jetson)
  • About Using Problem: Please first check if the firmware version of the CamArray HAT is the latest version.
Check the firmware information:
  • Download the library
git clone https://github.com/edward-ardu/tools
  • Use the template
python3 Detect_HAT_Firmware_Date.py -y <i2c-bus>
[Example]
For NVIDIA Jetson: Set i2c bus, for A02 is 6, for B01 is 7 or 8, for Jetson Xavier NX it is 9 and 10. Xavier NX csi port 0:
python3 Detect_HAT_Firmware_Date.py -y 9
Then there will be a date returned:
If it returns 2000-0-0 or returns some weird date then it is not the latest version:
