IMX500 MCU AI Camera¶
Mode Introduction¶
Arducam MCU AI Camera Module (B0564) supports SPI / USB interfaces and two operating modes:
Deploy Mode¶
Main Features:
- No image output
- Works with both SPI and USB interfaces
- Outputs only AI inference data
- Suitable for model deployment
Preview Mode¶
Main Features:
- USB interface only
- Outputs image data
- Preview camera feed with
IMX500PreviewGUI - Suitable for installation, debugging, and image preview
Quick Start Guide¶
Get AI inference data via USB¶
Hardware Preparation
- Arducam MCU AI Camera Module (SKU: B0564)
- USB Type-C Cable
- Windows PC Device
Install Dependencies
cd arducam_imx500_mcu_serial_example
pip install -r requirements.txt
- Run the example
python serial_deploy_mode_demo.py
After starting the program, please use the arrow keys to select the serial port and press Enter.
You will then see bounding boxes drawn based on AI inference results:
Get AI inference data via SPI¶
- Hardware Preparation
1. The following demonstration is based on Arduino Uno R3 Development Board.
2. The multi-camera adapter board is designed for testing multiple B0564 camera modules simultaneously. When using a single module, you can connect it directly to the main board using an SPI cable.
- Arduino Uno R3 board
- Arducam Multi-Camera SPI Adapter Board for Arduino Uno R3
- 6-pin SPI Cable
- USB Type-B Cable
- Windows PC Device
This example uses Arduino Uno R3 to receive AI data via SPI and forward it to the USB serial port.
- Hardware Connection
Connect Arduino Uno R3 to the PC using a Type-B USB cable.
Select Arduino IDE
- Please install Arduino IDE Tool
- Open the project
arducam_imx500_mcu_spi_arduino_uno_r3_example/main/main.inoin Arduino IDE. - Select the correct board in Arduino IDE and upload the firmware.
- Wire the devices as shown below:
Connect Arducam MCU AI Camera (B0564) to Arduino Uno R3 Board:
Once wired all the devices, please refer to the Get AI inference data via USB to view inference results on the PC.
Image Preview Mode¶
There is a **Mode** button on the back of the Arducam IMX500 MCU AI Camera Module.
- Hold down the
**Mode button**while connecting the camera to the PC with a Type-C USB cable - The red LED on the side will turn on, indicating
Preview Mode
⚠️Some older versions of Windows OS may require libusb driver installation. If so, please download zadig, run it, and install as shown below:
Download preview tool: Go to IMX500 SPI Examples - Releases to get IMX500PreviewGUI.exe.
After launching the software:
- Click the
Openbutton - Click the
Playbutton to preview the camera in real time
Model Switching¶
- Connect the camera to the PC via Type-C USB. A flashing green LED indicates Deploy Mode.
- In Deploy Mode, long press the Mode button (>2s), and the PC will mount a USB drive named IMX500.
- Copy a
.admmodel file to the drive to complete model switching.
.adm model files are available in the arducam_imx500_model_zoo project.
For example you can switch the yolov8n_pos adm model to implement human pose estimation applications.
More Resources¶
Github - Arducam AI Model Zoo Source Code
