8.3MP IMX415
B0569 · RASPBERRY PI CAMERA GUIDE
Connect the Sony IMX415 camera to your Raspberry Pi and start a live preview using the system-provided libcamera stack and rpicam-apps.
8.3 MP3840 × 2160 resolution
STARVISSony IMX415 sensor
MIPI CSI-2Camera interface
What you will do: connect the camera, configure its port, verify detection, and preview with the B0569 tuning file.
View B0569 product details →
Product specifications · sensor, lens and field of view
ProductArducam B0569
SensorSony IMX415 STARVIS
Resolution8.3 MP; 3840 × 2160
Pixel size1.45 µm × 1.45 µm
InterfaceMIPI CSI-2
FocusFixed focus; 3 m to infinity
Field of view (D × H × V)104° × 88° × 47°
IR filterIntegrated 650 nm IR-cut filter
Available sensor modes and frame rates depend on the driver and platform. Use the camera detection command below to check the modes exposed by your system. Sensor-mode dimensions may differ from the requested output image size.
Before you begin
  • Raspberry Pi with a camera connector, or a Compute Module with a suitable carrier board.
  • Raspberry Pi OS with Linux kernel 6.12.25 or later.
  • The system-provided libcamera and rpicam-apps, including the B0569 tuning file for your platform.
  • A compatible CSI cable and a local display for preview.
Check the kernel version:
uname -r
Use the software already on your Pi
Use the libcamera software supplied with Raspberry Pi OS. A separate Arducam libcamera installation is not required for this camera.
1. Connect the camera
  1. Shut down the Raspberry Pi and disconnect its power supply.
  2. Connect the camera using the appropriate CSI cable. Check the connector orientation and secure both ends.
  3. On boards with multiple camera connectors, note which port you use. The overlay configuration must match that port.
  4. Reconnect power and start the Raspberry Pi.
For cable selection and connector orientation, see the hardware connection guide.
2. Configure the camera
Open the configuration file
Select the camera port
Set camera_auto_detect=0 and add the IMX415 overlay under the [all] section. If the settings already exist, edit them instead of adding duplicate entries.
For a Raspberry Pi with a single camera connector, or for CAM1 on a board with two camera ports, use:
[all]
dtoverlay=imx415
For CAM0 on Raspberry Pi 5, CM4, or CM5, use this configuration instead:
[all]
dtoverlay=imx415,cam0
Choose the configuration for the connected port. For a single-camera setup, do not add both overlay lines. Remove or comment out any conflicting camera overlay assigned to that port.
Compute Module carrier boards
Match the configuration to the carrier board's camera-port routing. Check the carrier board documentation if its connector labels differ from CAM0 and CAM1.
Save and reboot
In nano, press Ctrl+O, then Enter to save, and Ctrl+X to exit. Reboot to apply the changes:
sudo reboot
3. Verify camera detection
After rebooting, list the available cameras and sensor modes:
rpicam-hello --list-cameras
Detection confirmed
An IMX415 camera appears in the output, together with its available sensor modes and frame rates.
If no camera is listed, follow the troubleshooting steps below before starting the preview. The presence of /dev/video* nodes alone does not confirm that the IMX415 is ready for use.
4. Start the preview
Use the command for your Raspberry Pi model. Both commands explicitly load the B0569 tuning file for the corresponding image-processing pipeline.
Raspberry Pi Zero–4 / CM4
VC4 pipeline · Use the tuning file in the vc4 directory.
rpicam-still -t 0 --tuning-file /usr/share/libcamera/ipa/rpi/vc4/imx415_b0569.json
Raspberry Pi 5 / CM5
PiSP pipeline · Use the tuning file in the pisp directory.
rpicam-still -t 0 --tuning-file /usr/share/libcamera/ipa/rpi/pisp/imx415_b0569.json
Preview confirmed
A live camera preview appears on the connected display. Press Ctrl+C in the terminal to stop.
The -t 0 option keeps the preview running until stopped. These commands preview the camera without saving an image file. For image capture and other operations, see the libcamera and rpicam-apps user guide, and continue to specify the matching B0569 tuning file.
Multiple cameras
If multiple cameras are listed, append --camera N to select the intended camera using the index reported by --list-cameras. This application index is not necessarily the physical connector number.
Troubleshooting
Start with the symptom that matches your setup.
What you see Where to start
IMX415 is missing from the camera list Camera detection
The tuning file cannot be opened Tuning file checks
The camera is listed, but no preview appears Preview checks
Camera is not detected
Symptom: rpicam-hello --list-cameras does not list the IMX415.
  1. Power off the Raspberry Pi and check the CSI cable orientation and seating.
  2. Confirm that camera_auto_detect=0 and the correct IMX415 overlay are active under [all].
  3. Check that the overlay matches the physical camera port, including ,cam0 where required.
  4. Reboot after changing the configuration.
  5. Check the kernel log for sensor or connection errors:
sudo dmesg | grep -i imx415
Use the log as diagnostic information, then repeat rpicam-hello --list-cameras to verify detection.
Tuning file cannot be loaded
Symptom: the preview command reports that the tuning file is missing or cannot be opened.
Check the file for your platform.
Raspberry Pi Zero–4 / CM4:
ls -l /usr/share/libcamera/ipa/rpi/vc4/imx415_b0569.json
Raspberry Pi 5 / CM5:
ls -l /usr/share/libcamera/ipa/rpi/pisp/imx415_b0569.json
Confirm the path and file permissions. If the file is absent, check that the Raspberry Pi OS camera packages include the B0569 tuning data. The kernel version alone does not confirm that this user-space file is installed. Use the file for the correct pipeline; do not substitute the VC4 file for PiSP or vice versa.
Camera is detected, but no preview appears
  1. Run the preview command from a terminal on the Raspberry Pi's local desktop with a display connected. An SSH session alone does not provide a local preview window.
  2. Confirm that the command uses the tuning-file path for your platform.
  3. Close other applications that may be using the camera.
  4. If more than one camera is connected, check the selected camera index.
  5. Record the complete terminal error output and consult the common troubleshooting guide.
For further assistance, provide the camera SKU, Raspberry Pi model, camera port, output of uname -r and rpicam-hello --list-cameras, and the exact preview command and error output.
