IMX500 PoE-Lite AI Camera
Mode Introduction
The Arducam PoE-Lite AI Camera (B0565) supports Ethernet interfaces and two operating modes:
Deploy Mode
Main Features:
  • No image output
  • Works with both SPI and USB interfaces
  • Outputs only AI inference data
  • Suitable for model deployment
Preview Mode
Main Features:
  • Works with Ethernet Interface
  • Outputs image data
  • Preview camera feed with IMX500PreviewGUI
  • Suitable for installation, debugging, and image preview
Quick Start Guide
Important Note
Accessing `Arducam B0565` via WIFI is not currently supported, and related functions will be optimized in the future.
Hardware Connection
  • Hardware Preparation
    1. Arducam PoE-Lite AI Camera (B0565)
    2. Ethernet cables
    3. Windows x86 PC/Linux x86 PC
    4. POE power supply module
    5. A switch or router that supports DHCP
Use a PoE power supply module to power the B0565, and connect the PC and B0565 to the same LAN using an Ethernet cable.
Get the device IP
Device Identification
The MAC address of a device is unique and can be used to mark the device.
  • Install Dependencies
cd arducam_imx500_poe_mcu_example
pip install -r requirements.txt
  • Run the example
python .\imx500_poe_discovery_demo.py
arducam_wiki_imx500_poe_lite_ai_camera_qsg_picture_1
Get AI inference data via Ethernet
  • Run the example
python imx500_poe_deploy_mode_demo.py
After starting the program, please use the arrow keys to select the device ip and press Enter.
arducam_wiki_imx500_poe_lite_ai_camera_qsg_picture_2
You will then see bounding boxes drawn based on AI inference results:
arducam_wiki_imx500_poe_lite_ai_camera_qsg_picture_3
Image Preview Mode
Download preview tool: Go to IMX500 PoE-Lite Examples - Releases to get IMX500PreviewGUI.exe.
After launching the software:
  1. Select option B0565
  2. Click the Refresh and wait for a moment. The IP Address will be refreshed in the drop-down box.
    arducam_wiki_imx500_poe_lite_ai_camera_qsg_picture_4
  3. Select the device IP.
  4. Click Open to init preview mode.
  5. Click Play to start previewing.
    arducam_wiki_imx500_poe_lite_ai_camera_qsg_picture_5
    arducam_wiki_imx500_poe_lite_ai_camera_qsg_picture_6
Model Switching
Important Warning
Do not interrupt the model burning process!!! If the model burning process is interrupted, please power on the device again.
Arducam IMX500 Model Zoo:
Go to Arducam IMX500 Model Zoo to download AI models.
  • Run the example
python imx500_poe_flash_demo.py --network-path <your model path>
arducam_wiki_imx500_poe_lite_ai_camera_qsg_picture_7
Wait for the program to end
arducam_wiki_imx500_poe_lite_ai_camera_qsg_picture_8
More Resources
Arducam AI Model Zoo
Github - Arducam AI Model Zoo Source Code
Arducam AI Model Converter Service
Partnership with SONY - Arducam IMX500 AI Camera Solution
