Arducam Discovery Tool
Windows Instructions
Download Device Discovery Program
  • Filter Programs by device model:
Check Status Check B0581 Only Check B0572 Only Check all devices with Discovery
Program arducam_listdevices.B0581_v1.0.1.exe arducam_listdevices.B0572_v1.0.1.exe arducam_listdevices_v1.0.1.exe
Product Info IMX500 CM5 All-in-one AI Camera Kit with CM5 inside IMX500 Outdoor Security AI Camera Kit with CM5 inside All Devices with Discovery
Run the Program
Double-click arducam_listdevices.exe
arducam_wiki_imx500_cm5_kit_picture_discovery_tool_1
Check IP address and Physical address
A pop-up window will display, when devices are properly connected, you can find the device's IPv4 address and the corresponding physical address to distinguish which device it is (Take B0572 as an example):
  • type: corresponding to the SKU of All-in-one Kit
  • IP: IP Address
  • MAC: Network card physical address
arducam_wiki_imx500_cm5_kit_picture_discovery_tool_2
Linux Instructions(amd64)
Download Program
Program arducam_listdevices_B0581_v1.0.1.tar arducam_listdevices_B0572_v1.0.1.tar arducam_listdevices_v1.0.1.tar
Run the Program
Open terminal, run the program
# Add execute permission
chmod +x arducam_listdevices*
# Execute the file
./arducam_listdevices*
arducam_wiki_imx500_cm5_kit_picture_discovery_tool_3
Check IP address and physical address
Take B0581 as an example:
arducam_wiki_imx500_cm5_kit_picture_discovery_tool_new1
Permanently Disable Discovery Service
Execute these commands via VNC terminal after login:
# Stop the service
sudo systemctl stop arducam-discovery
# Disable automatic startup
sudo systemctl disable arducam-discovery
# Remove service configuration
sudo rm /etc/systemd/system/arducam-discovery.service
# Verify removal
systemctl status arducam-discovery  # Should show "not found"
