Windows Graphical User Interface(GUI)
Abstract
Github - Arducam Camera Evaluation Kit GUI Download:
Latest Version of Windows GUI
Windows GUI
We provide a GUI so that you can get started quickly. You can click the link below to install it:
Click to download and double-click to install (the version will be continuously updated, please refer to the corresponding link for specific content)
Configuration File
Help Center
  1. The corresponding configuration file will be sent online when purchasing the product, please contact sales@arducam.com for details.
  2. If you need the corresponding camera kit config file that supports external trigger function, please contact sales@arducam.com - EVK External Trigger Mode for the configuration file.
Instructions
Take 48MP Evaluation Kit as an example:
Scan the Device
After connecting the device, scan the device to confirm that the device is connected normally, and the device serial number appears in the drop-down box on the left
Select the File
Load Config File
Open&Play the Camera
  • Open the camera
  • Play the camera
  • Preview
Store DNG format Images
Store RAW format Images
Control Menu
[Control Parameters]:
Control Parameters
  • Sensor_Focus: Adjust the focal length of the camera lens.
  • Exp(us): Adjust the camera exposure time, the unit is μs. For example, if the setting value is 24000, the corresponding physical duration is 24ms.
  • Gain(0.01x): Adjust the camera analog gain, the unit is 0.01. For example, if the setting value is 150, it means that the analog gain is 1.5.
For instance:
The camera configuration is just turned on, and the camera is in the initial state. The image is very dark. We want to adjust the camera control at this time to achieve the desired effect.
  • Initial Panel
  • Open the Control Panel
  • Adjust Parameters
We first adjust the gain. We can see that the gain increases and the image starts to become brighter.
Then adjust the exposure again, the picture is brighter (if you pull it too far, it will be overexposed):
We adjusted the focus and found that it was out of focus:
Then you can adjust the focus by pulling the slider to make the image clearer.
Demonstration
If you have any questions when using our products or you want to cooperate with us, you can get in touch with us quickly by contacting sales@arducam.com
