SDK API
There are a set of API functions that issue different commands to ArduCAM shield.
1. void InitCAM (void)
InitCAM function initializes the hardware information of the user system, such as the SPI chip select port initialization and image sensor slave address initialization.
2. void flush_fifo (void)
flash fifo function is used to reset the fifo read pointer to ZERO.
3. void start_capture (void)
start_capture function is used to issue a capture command. After this command the ArduCAM hardware will wait for a start of a new frame then store the entire frame data to onboard frame buffer.
4. void clear_fifo_flag (void)
Once a frame image is buffed to onboard memory, the capture completion flag is asserted automatically. The clear_fifo_flag function is used to clear this flag before issuing next capture command.
5. void write_reg(uint8_t addr, uint8_t data)
Param1: ArduChip register address (or command code)
Param2: data to be written into the register
write_reg is a basic function to write the ArduChip internal registers.
6. uint8_t read_reg(uint8_t addr)
read_reg is a basic function to read ArduChip internal register value.
7. uint32_t read_fifo_length(void)
Return value: 32 bit length of captured image
read_fifo_length function is used to determine the length of current captured image. Note the Rev.C shield doesn’t support this feature.
8. void set_fifo_burst(void)
set_fifo_burst function is used to set the read memory into burst read mode. It should be called before burst memory read operation. Note the Rev.C shield doesn’t support this feature.
9. int wrSensorRegs8_8(const struct sensor_reg*)
Param1: sensor setting data array
Return value: error status
wrSensorRegs8_8 function is used to write array of settings into sensor’s internal register over I2C interface and sensor’s register is accessed with 8bit address and 8bit data.
10. int wrSensorRegs8_16(const struct sensor_reg*)
wrSensorRegs8_16 function is used to write array of settings into sensor’s internal register over I2C interface and sensor’s register is accessed with 8bit address and 16bit data.
11. int wrSensorRegs16_8(const struct sensor_reg*)
wrSensorRegs16_8 function is used to write array of settings into sensor’s internal register over I2C interface and sensor’s register is accessed with 16bit address and 8bit data.
12. int wrSensorRegs16_16(const struct sensor_reg*)
wrSensorRegs16_16 function is used to write array of settings into sensor’s internal register over I2C interface and sensor’s register is accessed with 16bit address and 16bit data.
13. byte wrSensorReg8_8(int regID, int regDat)
Param1: sensor internal register address
Param2: value to be written into the register
wrSensorReg8_8 function is used to write a single sensor’s internal register over I2C interface and sensor’s register is accessed with 8bit address and 8bit data.
14. byte wrSensorReg8_16(int regID, int regDat)
wrSensorReg8_16 function is used to write a single sensor’s internal register over I2C interface and sensor’s register is accessed with 8bit address and 16bit data.
15. byte wrSensorReg16_8(int regID, int regDat)
wrSensorReg16_8 function is used to write a single sensor’s internal register over I2C interface and sensor’s register is accessed with 16bit address and 8bit data.
16. byte wrSensorReg16_16(int regID, int regDat)
wrSensorReg16_16 function is used to write a single sensor’s internal register over I2C interface and sensor’s register is accessed with 16bit address and 16bit data.
17. byte rdSensorReg8_8(uint8_t regID, uint8_t* regDat)
Param2: value read from the register
rdSensorReg8_8 function is used to read a single sensor’s internal register value over I2C interface and sensor’s register is accessed with 8bit address and 8bit data.
18. byte rdSensorReg16_8(uint16_t regID, uint8_t* regDat)
rdSensorReg16_8 function is used to read a single sensor’s internal register value over I2C interface and sensor’s register is accessed with 16bit address and 8bit data.
19. byte rdSensorReg8_16(uint8_t regID, uint16_t* regDat)
rdSensorReg8_16 function is used to read a single sensor’s internal register value over I2C interface and sensor’s register is accessed with 8bit address and 8bit data.
20. byte rdSensorReg16_16(uint16_t regID, uint16_t* regDat)
rdSensorReg16_16 function is used to read a single sensor’s internal register value over I2C interface and sensor’s register is accessed with 16bit address and 16bit data.
21. void OV2640_set_JPEG_size(uint8_t size)
Param1: resolution code
OV2640_set_JPEG_size function is used to set the desired resolution with JPEG format for OV2640. Current support resolution is shown as follows:
Sensor_Res No. Resolution
#define OV2640_160x120 0 //160x120
#define OV2640_176x144 1 //176x144
#define OV2640_320x240 2 //320x240
#define OV2640_352x288 3 //352x288
#define OV2640_640x480 4 //640x480
#define OV2640_800x600 5 //800x600
#define OV2640_1024x768 6 //1024x768
#define OV2640_1280x1024 7 //1280x1024
#define OV2640_1600×1200 8 //1600×1200
22. void OV5642_set_JPEG_size(uint8_t size)
OV5642_set_JPEG_size function is used to set the desired resolution with JPEG format for OV5642. Current support resolution is shown as follows:
#define OV5642_320x240 0 //320×240
#define OV5642_640×480 1 //640×480
#define OV5642_1024x768 2 //1024x768
#define OV5642_1280x960 3 //1280x960
#define OV5642_1600x1200 4 //1600x1200
#define OV5642_2048x1536 5 //2048x1536
#define OV5642_2592x1944 6 //2592x1944
23. void OV5640_set_JPEG_size(uint8_t size)
OV5640_set_JPEG_size function is used to set the desired resolution with JPEG format for OV564. Current support resolution is shown as follows:
#define OV5640_320x240 0 //320×240
#define OV5640_352x288 1 //352×288
#define OV5640_640x480 2 //640×480
#define OV5640_800x480 3 //800×480
#define OV5640_1024x768 4 //1024×768
#define OV5640_1280x960 5 //1280×960
#define OV5640_1600x1200 6 //1600×1200
#define OV5640_2048x1536 7 //2048×1536
#define OV5640_2592x1944 8 //2592×1944
24. void set_format(byte fmt)
set_format function is used to set the sensor between RGB mode and JPEG mode. The InitCAM function should be called after set_format function.
