Jetson-io
If your Nvidia Jetson Nano and Xavier NX boards are running L4T R32.6.1 or later versions, you can configure the CSI interface with jetson-io.
To check the L4T version, run the following command.
cat /etc/nv_tegra_release
How to manually configure your Jetson Nano/NX’s camera interface
If you are using the Arducam driver, use the following command to launch jetson-io:
sudo /opt/arducam/jetson-io/jetson-io.py
Otherwise use the following command:
sudo /opt/nvidia/jetson-io/jetson-io.py
Step 1. Select “Configure Jetson Nano CSI Connector” and hit enter on your keyboard
jetson io screenshot jetson CSI
Step 2. Select “Configure for compatible hardware” and hit enter again
jetson nano nx csi connector configuration
Step 3. Choose your camera of choice and hit enter
csi camera interface settings
Step 4. Select “Save pin changes” and hit enter
jetson nano csi pin changes
Step 5. Select “Save and reboot to reconfigure pins” and hit enter
save and reboot to reconfigure pins
Step 6. Reboot
reboot your jetson nano or xavier nx
Application Note - Fix Red Tint with ISP Tuing
