Arducam ToF Camera SDK – for Raspberry Pi
About SDK
A software development kit (SDK) is a collection of software development tools in one installable package. They facilitate the creation of applications by having a compiler, debugger and sometimes a software framework. They are normally specific to a hardware platform and operating system combination.
Software Stack of Arducam ToF Camera
ArduCam TOF SDK is a dynamic link library written in C++, There are three classes, Camera, Frame, and Sensor. Camera is responsible for managing camera image acquisition calculation, Frame is responsible for memory management of camera data storage, and Sensor is the specific implementation of calling the camera. It is called as a member object in the Camera class, and users generally do not touch it.
Using Arducam ToF Camera SDK
SDK Installation
The SDK will be installed together with the camera driver and necessary dependencies when you complete running the following steps. It is the same set of commands as Step1,2,3 instructed in .
Step 1. Pull the repository.
Step 3. Installation (Driver, Dependencies, SDK, OpenCV)
Running Examples
Examples with C
SDK workflow
- create a camera instance.
- start the camera.
- request a frame.
- get frame data
- release frame space
- stop the camera
Demo
#include "ArduCamDepthCamera.h"
#include <stdlib.h>
#include <stdio.h>
void getPreview(uint8_t *preview_ptr, float *phase_image_ptr, float *amplitude_image_ptr)
unsigned long int len = 240 * 180;
for (unsigned long int i = 0; i < len; i++)
uint8_t amplitude = *(amplitude_image_ptr + i) > 30 ? 254 : 0;
float phase = ((1 - (*(phase_image_ptr + i) / 2)) * 255);
uint8_t depth = phase > 255 ? 255 : phase;
*(preview_ptr + i) = depth & amplitude;
int main()
ArducamDepthCamera tof = createArducamDepthCamera();
FrameBuffer frame;
if (init(tof,CSI,DEPTH_TYPE,0))
exit(-1);
if (start(tof))
exit(-1);
uint8_t *preview_ptr = malloc(180*240*sizeof(uint8_t)) ;
float* depth_ptr = 0;
int16_t *raw_ptr = 0;
float *amplitude_ptr = 0;
FrameFormat format;
if ((frame = requestFrame(tof,200)) != 0x00){
format = getFormat(frame,DEPTH_FRAME);
for (;;)
depth_ptr = (float*)getDepthData(frame);
printf("Center distance:%.2f.\n",depth_ptr[21600]);
amplitude_ptr = (float*)getAmplitudeData(frame);
getPreview(preview_ptr,depth_ptr,amplitude_ptr);
releaseFrame(tof,frame);
if (stop(tof))
exit(-1);
return 0;
Content in CMakeList.txt
cmake_minimum_required(VERSION 3.4)
SET(CMAKE_BUILD_TYPE "Debug")
SET(CMAKE_CXX_FLAGS_DEBUG "$ENV{CXXFLAGS} -O0 -Wall -g2 -ggdb")
project(example_tof)
include_directories(BEFORE /usr/include/c /usr/include/cpp)
add_executable( example_tof your_filename.c )
target_link_libraries( example_tof ArducamDepthCamera_c pthread)
Compile & Run
Results
Examples with C++
*SDK workflow*
- initialize camera instance.
- start the camera.
- request a frame.
- get frame data
- stop the camera
Demo
#include "ArduCamTOFCamera.hpp"
#include <opencv2/core.hpp>
#include <opencv2/imgproc.hpp>
#include <opencv2/highgui.hpp>
#include <chrono>
#include <iostream>
// MAX_DISTANCE value modifiable is 2 or 4
#define MAX_DISTANCE 4
void display_fps(void)
static int count = 0;
++count;
static std::chrono::high_resolution_clock::time_point time_beg = std::chrono::high_resolution_clock::now();
std::chrono::high_resolution_clock::time_point time_end = std::chrono::high_resolution_clock::now();
std::chrono::duration<double, std::ratio<1, 1>> duration_s = time_end - time_beg;
if (duration_s.count() >= 1)
std::cout << "fps:" << count << std::endl;
count = 0;
time_beg = time_end;
auto len = 240 * 180;
for (auto i = 0; i < len; i++)
uint8_t mask = *(amplitude_image_ptr + i) > 30 ? 254 : 0;
float depth = ((1 - (*(phase_image_ptr + i) / MAX_DISTANCE)) * 255);
uint8_t pixel = depth > 255 ? 255 : depth;
*(preview_ptr + i) = pixel & mask;
cv::Rect seletRect(0, 0, 0, 0);
cv::Rect followRect(0, 0, 0, 0);
void onMouse(int event, int x, int y, int flags, void *param)
if (x < 4 || x > 251 || y < 4 || y > 251)
return;
switch (event)
case cv::EVENT_LBUTTONDOWN:
break;
case cv::EVENT_LBUTTONUP:
seletRect.x = x - 4 ? x - 4 : 0;
seletRect.y = y - 4 ? y - 4 : 0;
seletRect.width = 8;
seletRect.height = 8;
break;
default:
followRect.x = x - 4 ? x - 4 : 0;
followRect.y = y - 4 ? y - 4 : 0;
followRect.width = 8;
followRect.height = 8;
break;
int main()
ArduCam::ArduCamTOFCamera tof;
ArduCam::FrameBuffer *frame;
if (tof.init(ArduCam::CSI,ArduCam::DEPTH_TYPE)){
std::cerr<<"initialization failed"<<std::endl;
exit(-1);
if (tof.start()){
std::cerr<<"Failed to start camera"<<std::endl;
exit(-1);
// Modify the range also to modify the MAX_DISTANCE
tof.setControl(ArduCam::RANGE,MAX_DISTANCE);
ArduCam::CameraInfo tofFormat = tof.getCameraInfo();
float *depth_ptr;
float *amplitude_ptr;
uint8_t *preview_ptr = new uint8_t[tofFormat.height * tofFormat.width];
cv::namedWindow("preview", cv::WINDOW_AUTOSIZE);
cv::setMouseCallback("preview", onMouse);
for (;;)
frame = tof.requestFrame(200);
if (frame != nullptr)
depth_ptr = (float *)frame->getData(ArduCam::DEPTH_FRAME);
amplitude_ptr = (float *)frame->getData(ArduCam::AMPLITUDE_FRAME);
getPreview(preview_ptr, depth_ptr, amplitude_ptr);
cv::Mat result_frame(tofFormat.height, tofFormat.width, CV_8U, preview_ptr);
cv::Mat depth_frame(tofFormat.height, tofFormat.width, CV_32F, depth_ptr);
cv::Mat amplitude_frame(tofFormat.height, tofFormat.width, CV_32F, amplitude_ptr);
cv::applyColorMap(result_frame, result_frame, cv::COLORMAP_JET);
amplitude_frame.convertTo(amplitude_frame, CV_8U,255.0/1024,0);
cv::imshow("amplitude", amplitude_frame);
cv::rectangle(result_frame, seletRect, cv::Scalar(0, 0, 0), 2);
cv::rectangle(result_frame, followRect, cv::Scalar(255, 255, 255), 1);
std::cout << "select Rect distance: " << cv::mean(depth_frame(seletRect)).val[0] << std::endl;
cv::imshow("preview", result_frame);
if (cv::waitKey(1) == 27)
break;
display_fps();
tof.releaseFrame(frame);
if (tof.stop())
exit(-1);
return 0;
find_package( OpenCV REQUIRED )
include_directories( ${OpenCV_INCLUDE_DIRS} )
add_executable(example_tof your_filename.cpp )
target_link_libraries( example_tof ArducamDepthCamera ${OpenCV_LIBS} )
Compile & Run
Results
Example with Python
SDK workflow
- start the camera.
- request a frame.
- get frame data
- stop the camera
Demo
import sys
import cv2
import numpy as np
import ArduCamDepthCamera as ac
dir(ac)
def process_frame(depth_buf: np.ndarray, amplitude_buf: np.ndarray) -> np.ndarray:
depth_buf = np.nan_to_num(depth_buf)
amplitude_buf[amplitude_buf<=30] = 0
amplitude_buf[amplitude_buf>30] = 255
depth_buf = (1 - (depth_buf/2)) * 255
depth_buf = np.clip(depth_buf, 0, 255)
result_frame = depth_buf.astype(np.uint8) & amplitude_buf.astype(np.uint8)
return result_frame
selectRect_x1 = 0
selectRect_y1 = 0
selectRect_x2 = 0
selectRect_y2 = 0
followRect_x1 = 0
followRect_y1 = 0
followRect_x2 = 0
followRect_y2 = 0
def on_mouse(event, x, y, flags, param):
global followRect_x1,followRect_y1,followRect_x2,followRect_y2
global selectRect_x1,selectRect_y1,selectRect_x2,selectRect_y2
# if (x < 4 or x > 251 or y < 4 or y > 251):
# return
if event == cv2.EVENT_LBUTTONDOWN:
pass
elif event == cv2.EVENT_LBUTTONUP:
selectRect_x1 = x - 4 if x - 4 > 0 else 0
selectRect_y1 = y - 4 if y - 4 > 0 else 0
selectRect_x2 = x + 4 if x + 4 < 240 else 240
selectRect_y2= y + 4 if y + 4 < 180 else 180
else:
followRect_x1 = x - 4 if x - 4 > 0 else 0
followRect_y1 = y - 4 if y - 4 > 0 else 0
followRect_x2 = x + 4 if x + 4 < 240 else 240
followRect_y2 = y + 4 if y + 4 < 180 else 180
if __name__ == "__main__":
cam = ac.ArducamCamera()
if cam.init(ac.TOFConnect.CSI,ac.TOFOutput.DEPTH,0) != 0 :
print("initialization failed")
if cam.start() != 0 :
print("Failed to start camera")
cv2.namedWindow("preview", cv2.WINDOW_AUTOSIZE)
cv2.setMouseCallback("preview",on_mouse)
while True:
frame = cam.requestFrame(200)
if frame != None:
depth_buf = frame.getDepthData()
amplitude_buf = frame.getAmplitudeData()
amplitude_buf[amplitude_buf<0] = 0
amplitude_buf[amplitude_buf>255] = 255
cam.releaseFrame(frame)
cv2.imshow("preview_amplitude", amplitude_buf.astype(np.uint8))
result_image = process_frame(depth_buf,amplitude_buf)
result_image = cv2.applyColorMap(result_image, cv2.COLORMAP_JET)
cv2.rectangle(result_image,(selectRect_x1,selectRect_y1),(selectRect_x2,selectRect_y2),(128,128,128), 1)
cv2.rectangle(result_image,(followRect_x1,followRect_y1),(followRect_x2,followRect_y2),(255,255,255), 1)
print("select Rect distance:",np.mean(depth_buf[selectRect_x1:selectRect_x2,selectRect_y1:selectRect_y2]))
cv2.imshow("preview",result_image)
key = cv2.waitKey(1)
if key == ord("q"):
exit_ = True
cam.stop()
sys.exit(0)
Run
Results (to be updated soon)
API References for C
You can find C references here.
API References for C++
You can find C++ references here.
