Quick start
Access the camera with Gstreamer
You can refer to the following doc to access the cameras with Gstreamer:
Quick start
Arducam Displayer Tools
Install the driver
Step1. Download automatic installation script
wget https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/install_full.sh
Step2. Install the driver
chmod +x install_full.sh
./install_full.sh -m arducam
reboot
Enter y to reboot your device.
How to use the camera
Some of the video preview software tools like VLC player only supports formats like GRAY, YUV etc., it might not support Bayer format. In this case we provide a python demo script to illustrate how to open and preview our cameras with OpenCV. In the demo code the most important three steps should be followed.
The official SD Card Image provided by Nvidia comes with a Python version of OpenCV version 4.1.1.
  • Designate the VideoCapture apiPreference parameter as CAP_V4L2
  • Disable the RGB conversion
  • Shift the data bit to match with the camera real output bit width and do color conversion when necessary.
1. install the v4l2 python module
for python 3.x:
python1
sudo python3 get-pip.py
python2
python3
sudo pip3 install v4l2-fix
python4
python5
2. Download the demo code
python6
python7
3. Check whether the camera is detected
ls /dev/video0
python8
4. Check the video format supported
v4l2-ctl --list-formats-ext
5. Display images in real time
export DISPLAY=:0.0
Enter program directory:
Check the help message of the parameters:
python arducam_displayer.py -d 0
Run the demo:
Read the sensor register
Arducam MIPI Camera driver for Jetson Nano support accessing the registers of the camera sensor and driver board by ioctl. Refer to rw_sensor.c and rw_sensor.py for an example of how to use it.
  • rw_sensor.py help file
rw_sensor_help
  • rw_sensor.py demo
Read a single register
python rw_sensor.py -d 0 -r 0x3500
Read multiple registers
python rw_sensor.py -d 0 -r 0x3500 0x3501 0x3502
python rw_sensor.py -d 0 -r 0x3500 -v 0x01
Write multiple registers
python rw_sensor.py -d 0 -r 0x3500 0x3501 -v 0x01 0x02
Display in VLC
Some cameras support using VLC to capture images. But please notice that some formats will not be supported by VLC.
Preparation
Please first check if your camera formats can be supported.
# input the command to check the camera formats
sudo apt-get install -y v4l-utils
Use VLC
Open VLC media player
VLC1
Display the image
Press Ctrl+C
VLC2
【Video device name】→ select "/dev/video0"→ click 【Play】.
VLC3
Adjust exposure, gain, and frame rate
Press Ctrl+E, drag the sliders at "Exposure", "Gain" and "Frame_rate" to make adjustments under the "v4l2 control" tab.
VLC4
Next
Access Global Shutter Camera using external trigger snapshot mode
