16MP IMX298
Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Using Arducam Pivariety camera modules, users can get better performance and a wider variety of camera, lens options. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and camera modules (V1/V2/HQ). Now Arducam made it possible to provide well-tuned ISP for Pivariety camera modules with Auto Exposure, Auto White Balance, Lens Shading Correction, etc.
Image Sensor 16MP IMX298
Max. Resolution 4656H×3496V
Pixel Size 1.12um×1.12um
Optical Format 1/2.8”
Lens Spec Focal length: 4.04mm, F.NO: 2.0±5%, FOV: horizontal 62deg
Focus Type Motorized focus, programmable focus control
Frame Rate 4640×3472@10fps,
2320×1732@20fps,
3264×2464@15fps,
3840×2160@15fps,
2592×1944@20fps,
1920×1080@30fps,
1280×800@45fps,
1280×720@50fps
Sensor Output Format RAW10
ISP Output Format The output image format of JPG, YUV420, RAW, DNG The output video format of MJPEG, H.264
Interface Type 2-Lane MIPI
Board Size 40mm×40mm
At Arducam
Since the release of IMX298 image sensor, we have designed several versions with different features according to different needs: Motorized Focus, USB/UVC , M12/Stock Lens.
Motorized Focus
Arducam 16MP IMX298 Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see. Also, through our Pivariety solution, you can achieve the ISP Processing function with Raspberry Pi, such as Auto Exposure, Auto White Balance, Auto Gain Control, Lens Shading Correction, etc.
M12/Stock Lens
We equiped several different lens for these camera module. You can chose the Stock Lens Camera with Motorized Focus function and M12 Lens Camera that can be adjusted the focus manually.
Detailed parameters
Product Image SKU Pin/Connect Type Features Lens Type Field of View(H/V) Focus Type IR Sensitivity
Image B0323
(Discontinued)
22/Top High Resolution Stock Lens 62°(H) Autofocus 650nm IR-cut filter
Next
Quick Start
