2MP OV2311
Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Using Arducam Pivariety camera modules, users can get better performance and a wider variety of camera, lens options. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and camera modules (V1/V2/HQ). Now Arducam made it possible to provide well-tuned ISP for Pivariety camera modules with Auto Exposure, Auto White Balance, Lens Shading Correction, etc.
Global shutter cameras eliminate rolling shutter artifacts to better capture moving objects, and OV2311 is just one of them.
Sensor Model OV2311
Shutter Type Global Shutter
Active Pixels 1600×1300
Resolution 2MP
Image Sensor Format Type 1/2.9″
Pixel Size 3μm×3μm
Color Filter Array None(Monochrome)
At Arducam
Arducam 2MP OV2311 Global shutter camera module is mainly designed for Raspberry pi boards, and it can be connected directly to RPi’s CSI-2 camera interface without additional hardware. This camera is based on 1/2.9-inch Omnivision OV2311 image sensor which adopts OmniPixel3-GS™ technology to provide full-frame, sub-sampled, and windowed 8/10-bit MIPI images, and capable of operating at up to 60fps in full resolution at 2-lane MIPI bus with complete user control over image quality. Due to the sensor's high resolution, the OV2311 offers exceptionally accurate gaze- and eye-tracking capabilities, and it achieves high near-infrared quantum efficiency to minimize active illumination power and reduce the system power requirements.
Detailed parameters
Product Image SKU Pin/Connect Type Features Lens Type Field of View(HxV) Focus Type IR Sensitivity
B0381 22/Top Mono Global Shutter M12 83°(H) x 67.5°(V) Manual Focus without IR-cut filter
Next
Quick Start
