12MP IMX378
Based on Sony’s IMX378 high-quality image sensor, Arducam IMX378 camera module is a ready-to-use embedded vision solution for the Raspberry Pi family. With a resolution of 12.3MP and a V2-like form factor, it is compatible with any existing Pi models and works with the latest software from the foundation. It can be widely used in machine vision systems and outdoor applications.
Sensor Model | IMX378 |
IR Sensitivity | Bulit in 650nm IR-cut filter, Visible light only |
Active Pixels | 4056×3040 |
Resolution | 12.3 MP |
Image Sensor Format | 1/2.3″ |
Pixel Size | 1.55μm×1.55μm |
Video Modes on Raspberry Pi | RAW10: 1332×990@120fps; RAW12: 2028×1080@50fps, 2028×1520@40fps, 4056×3040@10fps |
Color Filter Array | Quad-Bayer RGB |
Output Format | RAW10/RAW12 |
Product
Product Image | SKU | Pin/Connect Type | Features | Lens Type | Field of View(D/H/V) | Focus Type | IR Sensitivity |
B0406 | 22/TOP | Wide Angle | Stock Lens | 95°(H) x 72° (V) | Fixed Focus | 650nm IR-cut filter | |
B0412 | High Resolution | 65°(H) x 48.8° (V) |
Hardware Connection
For Raspberry Pi 4B and 3B(3B+)
For Raspberry Pi CM3/CM4
For Raspberry Pi Zero
Software
Software Configuration
At present, we support using libcamera and raspistill to capture images with IMX378 camera, please refer to the following messages:
Modify the confix.txt file
Bookworm OS & Pi 5
For Raspberry Pi Bookworm users running on Pi 5, please execute:
camera_auto_detect=0
dtoverlay=imx378
#Save and reboot.
cam0
dtoverlay=imx378,cam0
#Save and reboot.
Bookworm/Bullseye OS & Pi 4
For Raspberry Pi Bookworm/Bullseye users running on Pi 4, please execute:
Bookworm OS on Pi4
dtoverlay=imx378
#Save and reboot.
Bullseye OS on Pi4
sudo nano /boot/config.txt
dtoverlay=imx378
#Save and reboot.
Bookworm/Bullseye OS & Pi 0 ~ Pi 3
For Raspberry Pi Bookworm/Bullseye users running on Pi 0 ~ 3, please execute:
Bookworm OS on Pi0-Pi3
dtoverlay=imx378
#Save and reboot.
Bullseye OS on Pi0-Pi3
dtoverlay=imx378
#Save and reboot.
Open a terminal
Run sudo raspi-config
Navigate to Advanced Options
Reboot your Pi
Open a terminal
Navigate to GL Driver
Select GL (Full KMS)
Reboot your Pi
Raspberry Pi Compute Module 3/4
For Raspberry Pi Compute Module 3/4:
Using libcamera to access the camera
The Raspberry Pi Bullseye system support using libcamera to capture images. Please make sure you have downloaded the official Bullseye as follows:
- List all cameras:
- Open a preview window:
- Save a jpg file in your pi after 5s preview:
Using raspistill to access the camera
The raspberry pi Bullseye system support using raspistill command to capture image too, you need to run the raspi-config to enable legacy, please see the following:
- Run raspi-config
Open your terminal and input sudo rapi-config
- Move to interface option
- Enable the legacy
- Save and reboot
- Detect the camera
If the camera is detected, the output will be the follows:
- Run the camera
Preview:
Save a file:
For more usage of raspistill or previous command, please refer to the following messages:
Getting Started with Raspberry Pi
