MIPI Camera Cable
Since the release of the Raspberry Pi IMX477 camera, due to the high scalability of the IMX477 camera, more and more embedded camera users hope to have a camera extension solution to complete their long-distance projects.
Arducam did it. Arducam is a company dedicated to open source hardware and software, specifically for Arduino and Raspberry Pi camera solutions.
At present, we have finished a lot of solutions for the needs of camera extension. The extension of the MIPI camera cable is one of them, and we have also realized the problems that some cameras want to use on Raspberry Pi zero and the ultra-long extension cable designed for 3D printing.
Catagory
15-22pin FPC Cable for Raspberry Pi Zero
22pin-22pin MIPI Cable for Raspberry Pi Zero
Camera Extension Cable for 3D Printing
Product
Product Image | SKU | Length | Pin Type | Supported Cameras | Package Content |
CB014 | 11.8''(30cm) | 15pin-22pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 1 x Flex 15pin-22pin cable for Pi Zero&W |
B0244 | 11.8''(30cm) | 15pin-22pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 2 x Flex 15pin-22pin cable for Pi Zero&W |
B0210 | 1.5''/2.8''/5.9'' | 15pin-22pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 1 x 150mm Flex 15pin-22pin cable 1 x 73mm Flex 15pin-22pin cable 1 x 38mm Flex 15pin-22pin cable |
CB008 | 1.5''(38mm) | 15pin-22pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 1 x 38mm Flex 15pin-22pin cable for Pi Zero&W |
CB013 | 2ft(60cm) | 15pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 1 x 60cm Flex 15pin cable for 3D Printing |
CB012 | 3.28ft(100cm) | 15pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 1 x 100cm Flex 15pin cable (black) for 3D Printing |
CB006 | 3.28ft(100cm) | 15pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 1 x 100cm Flex 15pin Camera Extension Cable |
CB007 | 6.56ft(200cm) | 15pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 1 x 200cm Flex 15pin Camera Extension Cable |
B0229 | 2''(5cm)/23.62''(60cm)/39.37''(100cm) | 15pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 1 x 5cm 15pin cable 1 x 60cm 15pin cable 1 x 100cm 15pin cable |
CB023 | 150mm | 22pin | Raspberry Pi/NVIDIA Jetson MIPI Camera | 1 x 150mm 22pin to 22pin camera cable |
Quick Start Guide
Hardware Connection
Abstract
The Camera Extension Cable just extends the connection distance between the camera and platform board, there is no difference with the common MIPI Connection Method.
Software
Abstract
You only need to refer to the original operation methods and instructions of the original cameras.
You can check your cameras and find the corresponding instructions below to use the Camera Extension Cable:
Raspberry Pi Native Camera
Sensor | Optical Size | Resolution |
OV5647 | 1/4'' | 5MP |
IMX219 | 1/4'' | 8MP |
IMX477 | 1/2.3'' | 12MP |
IMX378 | 1/2.3'' | 12MP |
IMX708 | 1/2.43'' | 12MP |
IMX519 | 1/2.53'' | 16MP |
64MP Camera | 1/1.7'' | 64MP |
User Guide
Please refer to the following link to execute the relative steps:
Quick Start Guide for Raspberry Pi Native Camera
For IMX378 Camera, please refer to the following link:
Quick Start Guide for Raspberry Pi IMX378 Camera
For IMX708 Camera, please refer to the following link:
Quick Start Guide for Raspberry Pi IMX708 Camera
Arducam Pivariety Camera
OV9782 | 1/4'' | 1MP |
OV2311 | 1/2.9'' | 2MP |
IMX462 | 1/2.8'' | 2MP |
AR0234 | 1/2.6'' | 2MP |
OG02B10 | 1/2.9'' | 2MP |
AR1820HS | 1/2.3'' | 18MP |
IMX230 | 1/2.4'' | 21MP |
User Guide
Quick Start Guide for Arducam Pivariety Camera
NVIDIA Jetson Native Camera
User Guide
Quick Start Guide for NVIDIA Jetson Native Camera
For IMX519 Camera, please refer to the following link:
Quick Start Guide for Arducam IMX519 Camera on NVIDIA Jetson
Arducam Jetvariety Camera
OV9281 | 1/4'' | 1MP |
User Guide
