64MP Hawkeye
A 64-megapixel ultra-high resolution autofocus camera module exclusively built for the latest and future generations of Raspberry Pis.
By bringing a sensor inside modern-day flagship phones to Raspberry Pi. you can take DSLR like still images at the maximum resolution of 9152 x 6944. And with an autofocus lens, the ePTZ, and the continuous-autofocus features (PDAF function is supported after September, 2023)
You now get more horsepower to build more applications, to cover more industries, to unlock more fields, at a much lower cost.
For seasoned makers, Pi Hawk-eye is designed to ensure you a smooth development, it is compatible with everything you already have: the v1/v2 form-factor, the MIPI CSI-2 connection, the latest libcamera software, the standard tripod mount, etc.
Sensor Model | 64MP Hawkeye |
Active Pixels | 9152 (H) × 6944 (V) |
Resolution | 64MP |
Image Sensor Format | Type 1/1.7″ |
Pixel Size | 0.8 µm x 0.8 µm |
Data Format | JPEG/YUV/RGB/RAW10 |
Motorized Focus
Arducam 64MP Hawkeye Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see.
Product
Product Image | SKU | Pin/Connect Type | Features | Lens Type | Field of View(D/H/V) | Focus Type | IR Sensitivity |
B0399 | 15/bottom | High Resolution | Stock Lens | 72°(H) x 54.6°(V) | Autofocus | 650nm IR cut filter | |
B0399B0091 | HDMI Extension Kit | ||||||
B0399U6248 | Ethernet Extension Kit | ||||||
B0399B0283 | Pan-Tilt Kit |
Supported Platforms and OS
Raspberry Pi 5 | √ | ||
Raspberry Pi 4B / 3B+ / 3A+ / Zero / Zero 2 W | √ | √ | |
Hardware Connection
Please refer to the following doc for common hardware connection method of RPI Camera:
Quick Start Guide - Hardware Connection
Software Guide
Abstract
The earliest Raspberry Pi Bullseye version supported is 5.15.30 the version before it can not be supported.
After Raspberry Pi Bullseye 6.1.21/Bookworm kernel, Arducam 64MP Hawkeye Camera starts to support PDAF function.
Raspberry Pi Bullseye OS 6.1.21 and Later/Bookworm OS
Step 2. Install libcamera
Step 4. Modify .Config file
- For Raspberry Pi Bookworm users running on Pi 5, please execute:
dtoverlay=arducam-64mp
#Save and reboot.
cam0
dtoverlay=arducam-64mp,cam0
#Save and reboot.
- For Raspberry Pi Bookworm/Bullseye users running on Pi 4, please execute:
Bookworm OS on Pi4
#Save and reboot.
sudo nano /boot/config.txt
#Save and reboot.
- For Bookworm/Bullseye users running on Pi 0 ~ 3, please execute:
Bookworm OS on Pi0-Pi3
#Save and reboot.
Bullseye OS on Pi0-Pi3
#Save and reboot.
Open a terminal
Run sudo raspi-config
Navigate to Advanced Options
Reboot your Pi
Open a terminal
Navigate to GL Driver
Select GL (Full KMS)
Reboot your Pi
Step5. Use libcamera to access Arducam 64MP Camera
Preview 5 seconds.
If you don't have a display screen, you can save an image without displaying it. And an image of test.jpg will be saved in the current directory.
For more instructions, please refer to: libcamera User Guide
Before Raspberry Pi Bullseye OS 6.1.21
Step 4. Install Camera drivers
Please reboot your Pi when you finish the installation.
Step5. Using libcamera to Access Arducam 64MP Camera
Preview 5 seconds.
AF/Manual Focus Function
Abstract
For cameras with focus motors, we have added autofocus parameters to enable single autofocus and continuous autofocus functions.
Please refer to the following doc for details:
Autofocus/Manual Focus Function for Arducam 64MP Camera
Controlling Raspberry Pi Cameras with Your Smartphone (Android)
If you require to control Arducam Pi Native Cameras on Android platform, you can refer to the following doc for details:
Access Arducam Cameras on Android Platform
