12MP IMX378
Based on Sony’s IMX378 high-quality image sensor, Arducam IMX378 camera module is a ready-to-use embedded vision solution for the Raspberry Pi family. With a resolution of 12.3MP and a V2-like form factor, it is compatible with any existing Pi models and works with the latest software from the foundation. It can be widely used in machine vision systems and outdoor applications.
Sensor Model IMX378
IR Sensitivity Bulit in 650nm IR-cut filter, Visible light only
Active Pixels 4056×3040
Resolution 12.3 MP
Image Sensor Format 1/2.3″
Pixel Size 1.55μm×1.55μm
Video Modes on Raspberry Pi RAW10: 1332×990@120fps; RAW12: 2028×1080@50fps, 2028×1520@40fps, 4056×3040@10fps
Color Filter Array Quad-Bayer RGB
Output Format RAW10/RAW12
Product
Product Image SKU Pin/Connect Type Features Lens Type Field of View(D/H/V) Focus Type IR Sensitivity
B0406 22/TOP Wide Angle Stock Lens 95°(H) x 72° (V) Fixed Focus 650nm IR-cut filter
B0412 High Resolution 65°(H) x 48.8° (V)
Hardware Connection
  • For Raspberry Pi 4B and 3B(3B+)
34B
  • For Raspberry Pi CM3/CM4
CM3
  • For Raspberry Pi Zero
ZERO
Software
Software Configuration
At present, we support using libcamera and raspistill to capture images with IMX378 camera, please refer to the following messages:
Modify the confix.txt file
  • Bookworm OS & Pi 5
For Raspberry Pi Bookworm users running on Pi 5, please execute:
camera_auto_detect=0
dtoverlay=imx378
#Save and reboot.
If you want to enable the camera kit on the cam0 port of Pi5, please refer to the following modifications:
dtoverlay=imx378,cam0
#Save and reboot.
  • Bookworm/Bullseye OS & Pi 4
For Raspberry Pi Bookworm/Bullseye users running on Pi 4, please execute:
Bookworm OS on Pi4
dtoverlay=imx378
#Save and reboot.
Bullseye OS on Pi4
sudo nano /boot/config.txt
dtoverlay=imx378
#Save and reboot.
  • Bookworm/Bullseye OS & Pi 0 ~ Pi 3
For Raspberry Pi Bookworm/Bullseye users running on Pi 0 ~ 3, please execute:
Bookworm OS on Pi0-Pi3
dtoverlay=imx378
#Save and reboot.
Bullseye OS on Pi0-Pi3
dtoverlay=imx378
#Save and reboot.
Open a terminal
Run sudo raspi-config
Navigate to Advanced Options
Reboot your Pi
Open a terminal
Navigate to GL Driver
Select GL (Full KMS)
Reboot your Pi
  • Raspberry Pi Compute Module 3/4
For Raspberry Pi Compute Module 3/4:
The latest software only supports one camera at this time, CM4 uses `CAM1` by default.
dt
Using libcamera to access the camera
The Raspberry Pi Bullseye system support using libcamera to capture images. Please make sure you have downloaded the official Bullseye as follows:
-Raspberry Pi Bullseye
  • List all cameras:
  • Open a preview window:
libcamera-still -t 0
  • Save a jpg file in your pi after 5s preview:
Using raspistill to access the camera
The raspberry pi Bullseye system support using raspistill command to capture image too, you need to run the raspi-config to enable legacy, please see the following:
  • Run raspi-config
Open your terminal and input sudo rapi-config
sudo raspi-config
  • Move to interface option
378-2
  • Enable the legacy
378-3-1
378-3-2
  • Save and reboot
sudo reboot
  • Detect the camera
vcgencmd get_camera
If the camera is detected, the output will be the follows:
378-5
  • Run the camera
Preview:
raspistill -t 0
Save a file:
For more usage of raspistill or previous command, please refer to the following messages:
Getting Started with Raspberry Pi
