1.58MP IMX296
The Sony IMX296 is a global shutter CMOS image sensor with a resolution of 1.6 megapixels and a pixel size of 3.4µm x 3.4µm. A global shutter sensor captures an entire image at once, unlike a rolling shutter sensor that scans an image line by line. This means that global shutter sensors can avoid distortion and motion blur when capturing fast-moving objects.
The Sony IMX296 sensor is suitable for various industrial and machine vision applications, such as robotics, inspection, surveillance, and high-speed imaging. It can also be used with different types of lenses, such as C/CS-mount lenses, and can be integrated with Arducam camera module for embedded system/platforms using.
Common Specs
Image Sensor | IMX296 |
Resolution | 1.58MP |
Optical Size | 1/2.9(6.3mm sensor diagonal) |
Number of effective pixels | 1440(H) × 1080(V) |
Pixel Size | 3.4μm × 3.4μm |
Interface | MIPI CSI-2 Interface |
Color Filter Array | Quad-Bayer RGB |
Frame Rate | 1440x1080@60fps |
Output Format | RAW10 |
Product
Product Image | SKU | Resolution | Sensor | Interface | Features | Focus Type | Focal Length | Field of View(DxHxV) | IR Sensitivity |
B0445 | 1.58MP | IMX296 | MIPI CSI-2 | Color Global Shutter | Manual focus | 6mm | 55°(D)x45°(H)x33°(V) | Integral IR-cut Filter |
Quick Start
Hardware
Hardware Connection for Raspberry Pi 4B / Pi Zero
Software
Please make sure you are running the latest version of Raspberry Pi OS. (January 28th,2022 or later releases, Debian version:11(Bullseye) or Bookworm OS). You need to update the config file and use libcamera apps.
Supported Platforms and OS
Raspberry Pi 5 | √ | ||
Raspberry Pi 4B / 3B+ / 3A+ / Zero / Zero 2 W | √ | √ | √ |
Software Configuration
Bookworm OS & Pi 5
For Raspberry Pi Bookworm users running on Pi 5, please execute:
camera_auto_detect=0
dtoverlay=imx296
#Save and reboot.
cam0
dtoverlay=imx296,cam0
#Save and reboot.
Bookworm/Bullseye OS & Pi 4
For Raspberry Pi Bookworm/Bullseye users running on Pi 4, please execute:
Bookworm OS on Pi4
dtoverlay=imx296
#Save and reboot.
Bullseye OS on Pi4
sudo nano /boot/config.txt
dtoverlay=imx296
#Save and reboot.
Bookworm/Bullseye OS & Pi 0 ~ Pi 3
For Raspberry Pi Bookworm/Bullseye users running on Pi 0 ~ 3, please execute:
Bookworm OS on Pi0-Pi3
dtoverlay=imx296
#Save and reboot.
Bullseye OS on Pi0-Pi3
dtoverlay=imx296
#Save and reboot.
Open a terminal
Run sudo raspi-config
Navigate to Advanced Options
Reboot your Pi
Open a terminal
Navigate to GL Driver
Select GL (Full KMS)
Reboot your Pi
Raspberry Pi Compute Module 3/4
For Raspberry Pi Compute Module 3/4:
