Quick Start Guide for Multi-Camera Adapter Board
Hardware
Abstract
Arducam offers multi-camera adapters to accommodate up to 4 camera modules on a single Raspberry Pi and switch between them quickly. The HAT-style quadruple adapter fits well with the Raspberry Pi A&B series, and the double adapter is perfect for the Pi Zero. You will read more about it in the following chapters.
  • Hardware Structure(Example as B012001)
  • Connect and Insert the Multi-Camera Adapter Board into Raspberry Pi
  • Connect the cameras to Multi-Camera Adapter Board
Software
Warning
We currently only guarantee that the Camera Adaptation is supported on Raspberry Pi Bullseye and Bookworm OS.
Supported Platforms and OS
Note for Supported Platform and OS
Platform Bookworm(rpicam/libcamera) Bullseye(libcamera) Buster(raspistill)
Raspberry Pi 5
Raspberry Pi CM3 / CM3+ / CM4
Update Kernel Version
Note: Please make sure your kernel version is up to date (at least 5.15.63 or later)
m1
How to update the Kernel bersion:
sudo apt-get update
sudo apt-get upgrade
Supported Cameras
The following cameras will need the corresponding driver to be accessed:
Sensor Resolution
OV5647 5MP
IMX219 8MP
IMX477 12MP
IMX708 12MP
IMX519 16MP
64MP Camera 64MP
Modify the Config.txt
For Quad-Camera Adapter Board(B012001):
sudo nano /boot/config.txt
#add Following content:
dtoverlay=camera-mux-4port,cam0-<camera sensor name>,cam1-<camera sensor name>,cam2-<camera sensor name>,cam3-<camera sensor name>
#Find the line "camera_auto_detect=1" and modify it:
camera_auto_detect=0
Please manually add the number of cam according to the number of cameras you have connected.
Example: if you have three IMX219 cameras connected, enter:
dtoverlay=camera-mux-4port,cam0-imx219,cam1-imx219,cam2-imx219
Demo(64mp)
m2
dmesg
m3
For Dual-Camera Adapter Board(B016601):
add:
dtoverlay=camera-mux-2port,cam0-<you camera sensor>,cam1-<you camera sensor>
Example: if you only have one IMX219 cameras connected, enter:
dtoverlay=camera-mux-2port,cam0-imx219
Run the Multi-Camera
Use libcamera apps to access the Multi-Camera
libcamera-still -t 0 --camera <choose camera num>
Example:
m6
Attention
For another libcamera apps like libcamera-raw, libcamera-vide, etc. You will need to manually add --camera <choose camera num> behind the command
Troubleshooting
1. Time-error-occurs-when-using-multi-camera-adapter-board-on-pi5
