Ethernet Extension Kit
Arducam Ethernet Cable Extension Solution is a cable extension kit that converts high speed MIPI CSI-2 interface into LAN connection so you can put a Raspberry Pi camera up to 15 meters away from your Raspberry Pi.
The kit works out of the box with any of the following cameras:
- Official camera module V1/V2/HQ
- Raspberry Pi Official Camera Module 3
- Arducam OV5647/IMX219/IMX477 Series
- Arducam 16MP IMX519 Series
- Arducam 64MP Series
No extra software/configuration is needed.
Product
SKU: U6248
Demonstration
Quick Start Guide
Hardware
- Step 1. Connect the Rx board to your Raspberry Pi
- Step 2. Connect the Tx board to your Camera
- Step 3. Connect the two board with the LAN Cable
Software
Abstract
We have adapted the Ethernet extension kit based on the basic firmware of cameras, you don't need to perform complex and cumbersome operations, you only need to refer to the original operation methods and instructions of the original cameras.
You can check your cameras and find the corresponding instructions below to use the Camera Extension Kit:
Raspberry Pi Native Camera
Sensor | Optical Size | Resolution |
OV5647 | 1/4'' | 5MP |
IMX219 | 1/4'' | 8MP |
IMX477 | 1/2.3'' | 12MP |
IMX708 | 1/2.43'' | 12MP |
IMX519 | 1/2.53'' | 16MP |
64MP Camera | 1/1.7'' | 64MP |
User Guide
Please refer to the following link to execute the relative steps:
Quick Start Guide for Raspberry Pi Native Camera
Extension Solution for Multi-Camera Kit
Abstract
Extend the connection between the Arducam Camarray HAT and Raspberry Pi, you can consider the following solution:
【SKU: U6248 LAN cable】
It transmits MIPI signal through LAN cable, which can be transmitted farther than through FFC cable, about 10M.
In this form, we have tried 3 meter of LAN cable before, and it works normally. The HDMI cable should be longer.
