Quick start
Hardware
Locate the camera connector (CSI). It’s on the side of the carrier board, opposite to the GPIO pins.
Pull up on the plastic edges of the camera port. Do it gently to avoid pulling it off.
- Push in the camera ribbon. Make sure the contacts are facing the heatsinks. Do not bend the flex cable, and make sure it’s firmly inserted into the bottom of the connector.
Ribbon Cable Contacts – 15pin-15pin
Silver Contacts facing inside to the heatsinks
Ribbon cable fully inserted to the bottom of the CSI connector
- Push the plastic connector down. Do it while holding the flex cable until the connector is back in place.
Software
For Nvidia Jetson native camera:
The following sensor are natively supported by Nvidia Jetson platfrom:
Resolution | Sensor |
8MP | imx219 |
12MP | imx477 |
16MP | imx519 |
Currently, IMX219 camera can only get the max resolution(3280x2464) on NVIDIA Orin NX.
You can refer to the below link to install the driver and access the cameras:
Quick-Start-for-Nvidia-Jetson-Native-Camera
For Arducam Jetvariety Camera:
2MP | AR0234 |
1MP | OV9281 |
2MP | OV2311 |
18MP | AR1820HS |
21MP | imx230 |
You can refer to the below link to install the Arducam MIPI driver and access these cameras:
