Quick start
Hardware
Connect the ribbon cable
Connect to the Camera Board | Connect to the Camarrary HAT | Connect to the Camarrary HAT |
Open the Jetson Nano connector (any one) in the direction of the arrow | Insert the ribbon cable into the connector with the contact side facing inward | Close the connector |
Plug Camarrary HAT into Jetson Nano GPIO Header
STEP1
STEP2
Plug Camarrary HAT into Jetson Nano USB Port
In addition to the above power supply mode, you can also choose to supply via USB
STEP1
STEP2
Final Effect
Software
Supported Platforms and JetPack L4T versions
Please refer to the following doc for specific supported Platforms and JetPack versions:
Supported Platforms and JetPack Version - Arducam Camera for NVIDIA Jetson
For Native camera
There is two types of native camera, respectively are imx219 and imx477
Product Image | SKU | Sensor | Resolution | Pin/Connect Type | Features | Lens Type | Field of View(HxV) | Focus Type | IR Sensitivity |
B0347N | IMX477 | 12MP | 15/Bottom | Stereo Camera | M12 | 75°(H) x 56°(V) | Manual Focus | 650nm IR-cut Filter | |
B0396 | IMX219 | 8MP | Quad Camera | Stock Lens | 62.2° (H) x 48.8° (V) | Fixed Focus | |||
B0265N | IMX477 | 12MP | 15/Bottom | Stereo Camera | CS | 65°(H) x 48.7°(V) | Manual Focus | 650nm IR-cut filter | |
B0397 | 12MP | Quad Camera | M12 | 75°(H) x 56°(V) | |||||
B0217J8 | IMX219 | 8MP | 15/Bottom | Stereo Camera | Stock Lens | 62.2° (H) x 48.8° (V) | Fixed Focus | 650nm IR-cut filter | |
B0388 | IMX519 | 16MP | 15/Bottom | Quad-Camera Kit | Stock Lens | 66°(H) x 49.5°(V) | Motorized Focus | 650nm IR-cut filter |
If you do not find your camera please contact us.(support@arducam.com)
IMX219
Step 1. Check whether the camera is detected
Step 2. Preview the camera feed in real time
3280x2464@21fps
FRAMERATE=21
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=3280,height=2464,framerate=$FRAMERATE/1" ! nvvidconv ! "video/x-raw(memory:NVMM),width=1432,height=1080,framerate=$FRAMERATE/1" ! nvoverlaysink
1280x720@60fps
FRAMERATE=60
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=1280,height=720,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
IMX477
Step1. Download automatic installation script
Step2. Install the driver
Enter y to reboot your device.
Step3. Check whether the camera is detected
Step4. Preview the camera feed in real time
4032x3040@20fps
4032×3040 exceeds the system resolution and requires zooming to display.
FRAMERATE=20
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=4032,height=3040,framerate=$FRAMERATE/1" ! nvvidconv ! "video/x-raw(memory:NVMM),width=1432,height=1080,framerate=$FRAMERATE/1" ! nvoverlaysink
1920x1080@60fps
FRAMERATE=60 # Framerate can go from 2 to 60 for 1920x1080 mode
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
IMX519
Sensor | Optical Size | Resolution |
IMX519 | 1/2.53'' | 16MP |
Step1. Download the bash script
Step2. Install the DriverFor Arducam Jetvariety camera
B0331 | OV9782 | 1MP | 15/Bottom | Color Global Shutter Quad Camera | M12 | 75°(H) x 46.8°(V) | Manual Focus | without IR-cut filter | |
B0267 | OV9281 | 1MP | 15/Bottom | Mono Global Shutter Quad Camera | M12 | 75°(H) x 46.8°(V) | Manual Focus | without IR-cut filter | |
B0266 | Mono Global Shutter Stereo Camera | 70°(H) x 43.75°(V) | |||||||
B0263 | OV9281 | 1MP | 15/Bottom | Mono Global Shutter Stereo Camera | M12 | 70°(H) x 43.75°(V) | Manual Focus | without IR-cut filter | |
B0264 | OV2311 | 2MP | 83°(H) x 67.5°(V) | ||||||
B0492N | AR0234 | 2MP | 22/Bottom | Color Global Shutter | M12 | 120°(D)×90°(H)×75°(V) | Manual Focus | Integrate IR-cut filter | |
B0217J5 | OV5647 | 5MP | 15/Bottom | Stereo Camera | Stock Lens | 54° (H) x 41° (V) | Fixed Focus | 650nm IR-cut filter |
Arducam Jetvariety Cameras
OV9782 | 1/4'' | 1MP |
OV9281 | 1/4'' | 1MP |
OV2311 | 1/2.9'' | 2MP |
AR0234 | 1/2.6'' | 2MP |
OV5647 | 1/4'' | 5MP |
How to access the camera
1. install the v4l2 python module
for python 3.x:
2. Download the demo code
4. Check the video format supported
5. Display images in real time
Enter program directory:
Example as OV2311 Stereo Camera:
#RAW8
#RAW10
GREY for RAW8 and Y16 for RAW10.
-width and -height indicate the width and height of the input image.
The command line will refresh the display of frames in real time.
Switch Composition Mode
Arducam Team has released the channel-switch function on specific Quad-Camera kits. You can refer to the following guide to switch the Composition Mode.
Check I2C node
You can input the following command to check if your camera kit supports switching the composition mode.
user:~ $ i2cdetect -l
i2c-1 i2c bcm2835 (i2c@7e804000) I2C adapter
i2c-22 i2c bcm2835 (i2c@7e205000) I2C adapter
i2c-0 i2c i2c-22-mux (chan_id 0) I2C adapter
i2c-10 i2c i2c-22-mux (chan_id 1) I2C adapter
If you get some messages as above, then you can continue the following steps:
Detect I2C signal
Take i2c 10 node as an example
Select the Channel:
Example:
# Set to single channel 0
i2cset -y 10 0x24 0x24 0x02
# Set to single channel 1
i2cset -y 10 0x24 0x24 0x12
# Set to single channel 2
i2cset -y 10 0x24 0x24 0x22
# Set to single channel 3
i2cset -y 10 0x24 0x24 0x32
# Set to double channel (single channel 0 and single channel 1)
i2cset -y 10 0x24 0x24 0x01
# Set to double channel (single channel 2 and single channel 3)
i2cset -y 10 0x24 0x24 0x11
# Set to four in one mode (Default)
i2cset -y 10 0x24 0x24 0x00
Function Test
Single-channel test:
After setting the channel, you can directly use the gst-launch-1.0
command to capture images.
Dual-channel test:
By default, the quad-camera kit works in synchronized 4-channel mode, and NVIDIA Jetson recognizes the whole kit as one camera Any manual focus or camera control adjustments (exposure/gain/white balance/etc.) will also be applied to 4 cameras at the same time.
If you encounter any problems when using the camera kit, please directly contact support@arducam.com for help.
